Question about Electrolux Dishwashers
I have Electrolux fdbb2455fb2 dishwasher. Has worked fine till last couple of mos. every now and the the unit won't drain the water. Not every time, but becoming more frequent. What is the problem?
  • 825 Answers
Could be the drain is blocked.......
cheers
Posted on Jul 30, 2017
6ya staff
SOURCE:
Anonymous
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
Anonymous
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
douglas smith
  • 1462 Answers
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Posted on Nov 26, 2008
Anonymous
SOURCE: No power for my Siemans SL84A dishwasher
Not a solution but a cause for my DW having the same problem. One of the four wires going to the On/Off switch shorted and burned. I never lost power to the unit, as far as I know there is no reset button of fuse. I rewired the unit and ran several washes without overheating or shorting.
Posted on May 03, 2009
tjs95501
SOURCE: electrolux dishwasher won't drain
did u fix this? having same problem
Posted on May 31, 2010
Cannot find leak in this Electrolux dishwasher
If you are getting the E01 error code for a leak being detected, it could be the unit is not installed correctly and not leveled properly. That can throw the leak/water sensor off big time. Contact a professional - this might be covered under a limited warranty with your manufacturer.
Sep 03, 2012 | Electrolux Dishwashers
Electrolux professional series not pumping water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
Electrolux dishwasher model #EIDW6105GS1 My dishwasher was installed one and a half years ago and has worked beautifully and quietly until recently. The last three times I have washed dishes I hear the...
turn water off....remove the dishwasher....load it into the back of your pickup truck...take it to the recyclers....go to town and buy a different unit....NOT THIS ONE...this machine will never get any better...the only good thing about it is that it looks nice.....
Aug 29, 2011 | Electrolux Dishwashers
Water won't drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
May 27, 2011 | Electrolux Dishwashers
WATER REMAINS IN WASHER AFTER CLEANING CYCLE
Possible that the drain is blocked/choked or the drain pump/valve is faulty. You must remove the drain valve/pump and make a good cleaning of the unit . check on the outside with the voltage sepcified to confirm.
Finally make sure that the program controller unit supplies voltage to the unit till the water drains off. if not the time and the drain flow can be low. Keep the washer tilted to the drain flow.
Feb 14, 2011 | Electrolux 23 in. ESL624 Built-in...
Electrolux error code 1, how to reset.
Also got error code 01. Unplugged dishwasher, turned off water supply, disconnected water supply line at sink so it had slack to pull dishwasher out of built-in space, removed two wood screws holding dishwasher to counter, pulled it out onto floor, put it on blocks as reader suggested, tilted to side 45 degrees, water drained out onto rags. Then restored to upright, restored supply line and opened valve at sink, plugged back in, unit automatically reset, returned to built-in, reinstalled screws to counter. Worked like a charm. Took more time to read everyone's advice than to do the job (about 30 min.). Thanks.
May 20, 2010 | Dishwashers
My electrolux ex302 not working the water is not
You may have an issue with the heat element or thermostat (if applicable). Contact an appliance service company.
Feb 20, 2010 | Electrolux Dishwashers
THERE IS A COUPLE INCHES OF WATER IN BOTTOM AFTER CLEAN AND DRY CYCLE IS COMPLETE
it sounds like your drain pipe is clogged up, clean the vent window out on bottom and it should be fine
Jul 24, 2009 | Electrolux Kenmore 24 in. Built-In...
Mar 03, 2009 | Siemens 24 in. SL84A305UC Built-in...
Dishwashers Logo
44 people viewed this question
Top Electrolux Dishwashers Experts
Mike
tglynn
Level 1 Expert
Colin Stickland
Colin Stickland
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
