"F02" is a Long Drain error code. It usually means you have something clogged in the drain pump, or restricting the drain lines. The following link explains how to check:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
If cleaning the pump does not correct the problem, a new drain pump may be required. If the pump impeller or motor is damaged and the pump does not pump at the proper volume, the error code will still occur. This is because the error is caused if the drain cycle takes longer than 8 minutes. If the pump is not moving the correct volume of water, the error code will still occur.
If a replacement pump is needed you can purchase them at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com or repairclinic.com. All these sites offer great service with competitive pricing. So shop all of them for the best deal. Use your model number (located around the door opening) for your search criteria.
If you have any questions, please let me know. I hope this helps you.
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
