SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
I have LNS4692D. Returned from vacation, turned tv on - no picture. Tried turning tv off for 4 hours- nothing. Symptoms are: tv is on - no picture , just sound; menu doesn't show, volume bar doesn't show;E.Saving is working - the backlight is changing from lighter to darker.
Found this website and ordered T-con, otherwise known as the LCD panel driver board, p/n# Bn8101286a ( thanks premtech) from partstore.com for $124. Part number BN81-01286A A/S T-CON Board.
Installation:
1.Remove plastic cover. There is an arrow for each screw that needs to be removed. Make sure to unscrew pins next to VGA port. I've spent some time trying to figure out what else is holding the plastic panel until I found this pins.
2. Remove big metal shield in the middle of tv that is covering main components. This shield is being held by small black screws all around it.
At this point you will see cover of T-CON. Here is the picture
http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118863&d=1220531321 (thanks ldac9). Do not attempt to remove that cover yet. Proceed with a next step
3.Remove metal panel that holds main components. Locate big chrome screws that have arrows pointing to them and unscrew them. Remove 2 more screws on the bottom of the panel that holds it together with a box for cables. At this point the main panel will be lose
4. Carefully start lifting the panel. You will see that there are connectors going from components on the panel to components on the lower panel and T-CON. Carefully unplug these components and raise the main panel.
5. Remove 4 screws that holds T-CON cover. Pull the cover so that T-CON is completely exposed. The cover is connected by thin alluminum , don't hesitate to pull it , but don't rip it out.
6. Once T-CON is exposed you will see 2 red ribbons. I've spent some time to figure out how unplug those from old T-CON board. Here is the suggestion. Don't try to pull it out. All you need to do is to lift small plastic lever that is part of a connector. Then ribbon can be slided out. If not sure what to do, see how this is done on the new T-CON. It has a principle of buckle on airplain safety belts.
7. Remove old T-CON and install new you.
8. Follow reverse order.
I've never fixed TV before , but this was totally successful project.
SOURCE: LCD TV no pic but sound, do have all screen glow..
What is the Samsung Model number so I can do a cross match of the Tcon board?
SOURCE: My Dynex TV model DX-LCD32-09 HAS FAILED AGAIN. I
Make sure when you relace it you have an antistatic inviroment, and grounded braclett on.
SOURCE: Samsung LN-S4692D with no picture no
T-Con board provides video signal to lcd panel (basically t-con board is part of lcd panel) and has nothing to do with sound in tv.
Please check power supply board is providing required volts to main board and if volt supplies are correct then main board could be defective because it has video and audio processors.
Hope this will help.
Thanks.
SOURCE: I have a olevia model 232-s12 tv has sound but no
Good day.
If you already replaced a new inverter board and T-con board and the problem is still there.Try to play the video on the DVD,if the video is OK check the cable connection and try to run auto scan.
If the problem is still there check the input supply of the system board or main board it should have 5vdc and 12vdc,if it is OK replace the system board.
Review this manual page 4-1 abnormal display http://www.scribd.com/doc/36875894/Olevia-232-S12-SM
I hope this solution will be helpful.Thank you for using FixYa.
