From my study of various forums, it is likely you have a problem with the IMA battery pack, most probably weak or shorted cells leading to a difference of more than 2 Volts between sections of the battery pack. Sometimes weak cells can be reconditioned with a full discharge/recharge cycle (often called rebalancing) to break up nickel dendrites inside the cell. The battery generally must be removed to perform this procedure.
However, before you tear apart your back seat to get at the IMA battery, check that the 12 V starter battery and its connections are good; problems here could cause errors in the IMA monitoring circuit. Make sure that any provisions for cooling the IMA battery compartment are working, i. e., that vent slots, cooling fins etc. are not blocked or loaded with dirt. The battery pack is cooled by a fan that blows through the battery from just behind the back seat; the air exhausts into the trunk from the IMA electronics section.
I also found these definitions:
P1449: Battery Module Overheating, Battery Cell Overheating, or Battery Module Deterioration
P1600 - IMA System Malfunction
P1601 - IMA System Malfunction without Indicator Lamp
Caution: the IMA battery has 120 Ni-Cd cells in series and can deliver a high-voltage shock (as high as 144-158 Volts) even when it is in poor condition.
Here is a well-written article on battery rebalancing/reconditioning:
Sucessfully Reconditioning an IMA Battery Pack GreenHybrid Hybrid Cars
You need a repair book on that car so you can look up the codes or call Honda and see if they will give you the codes and tell you what is wrong is the car even running good you can also take it to auto that has a reader they can put it on and they can tell you what they mean.
SOURCE: 2001 dodge truck wont start
dear friend:code p1601 stands for engine control module(ecm)transmission control unit(tcm)-serial peripheral comminication malfunction,code p1282 stands for fuel pump relay-open circuit,fuelpump relay faulty and p1687 stands for metering oil pump-high flow-circuit malfunction,(wiring metering oil pump switch metering oil pump and ecm
SOURCE: honda civic hubrid 2003 chek engine light is on
You should have it checked by a qualified tech. Auto zone dont do diagnostic repairs, they can only give you trouble codes.
SOURCE: My 2003 honda civic hybrid radio says "code" new
many peolple and parts store sales persons as well. they should have used a memory saver.you need to break out your manual on audio.the code should be there, if you don't have one you can call the honda dealer with your vin number explain your problem and they will give you the code.
SOURCE: what is the problem fault code p1601
Toyota Hilux?
wow no year, you do make it so hard to answer but is 96+
P1 means factory code, so autozones may fail.
5th generation 1996+
Engines:
2Y I4, 61 kW (83 PS; 82 hp) at 4,800rpm 140 N·m (100 lb·ft) at 2,800rpm (export markets)[11]
my wild guess is the 2.4L due to OBD2 status. only...you need to say..
my motto:
NO YEAR
NO MODEL
No engine size. (or transmission type A/T or M/T?, if that is in question)
NO HELP (or your joy)
No country , too , is a royal pain , all cars are different by country (laws)
