SOURCE: Freezer/fridge fluctuates freezing/cooling
Yes, that is one problem. The refrigerant needs to remove the excess heat through the condenser coils. If the air flow is blocked, it will do those symptoms you described.
SOURCE: the fridge ice maker isn't getting water
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Check close to the end I have suggestions on how to stop or eliminate delivery tube freeze ups.
Does it make Ice OK?
If so the ice-water valve may be at fault if neither work.
Eliminate water filter or frozen line to reservoir.
Make sure you have water to water valve
Shut off water, remove line, open water line. Catch water in container and
examine. Clean on particles let it flush out some more open and close til
clean. Verify pressure and flow.
Still no water?
Check voltage with a volt meter at the fill valve behind the refrigerator.
Attach volt meter to the coil wire plug just insert probes into them. Then push
the button on the door like your getting water. No volts? If has Ice maker pull
off the other set of wires on water valve and recheck with door switch. Still
no power? Problem in the ice - water door relay or control board.
If these check OK water valve is not opening when power applied replace water
valve. Power shows good replace water valve.
Normal
0
false
false
false
font-size:10.0pt;
You need an Ice maker book to tell you what it could be and
what to look for.. Too many items to mention here.
I recommend if your problem is actually the ice maker itself
get a new or rebuilt one. Too many things to detail to make sure it all works
out in the end. However you might replace it and still have a problem. So here
is a list of items to check external of the ice maker to eliminate what might
be something else.
First lets see if we can eliminate some things:
Itemized as
Temperature, Water, Water delivery… It is assumed the refrigerator has been
running and not making ice and has remained on (NOT UNPLUGGED AND OFF) freezing
as normal before starting any of these tests and observations. Other wise you
will have to start over with the problem at hand before proceeding.
External of the ice maker:
1st Does the Freezer temp get down to 12'F? . The temp of the
freezer has to be this cold or colder for the ice maker to work. Just because
meat stays frozen (28’F and colder) doesn't mean it will freeze ice (12’F and
colder) and dump it out. You have to know and record your findings to be
objective and not subjective.
If not your problem may not be the ice maker at all. Eliminate it as a source
of heat in the freezer. It’s plugged into the wall of the freezer and has a
heater that warms the ice up to turn it loose for “harvest”. Unplug or remove
it. Recheck the temp after ½ to 1 hour with the doors closed during this time.
If its still not to temp your ice maker may be ok.
A lot of things can cause the temp of the freezer to stay high. But if this is
the situation you need to look for a different problem before condemning and
buying an Ice maker replacement
2nd Does it get water into the ice maker? If the water isn't getting
to it you need to check the water delivery system, water supply, and water
valve in the back.
The water delivery is easiest to check by shutting off the water removing the
supply line and catching the water in a container with the valve open 1 to 2
rounds to flush out any particles and verify good flow and pressure, and makes
sure when you turn it on you have clean water..
After you have eliminated this;
Next if your not getting water to the delivery tube and into
the ice maker
1 of 2 things is stopping the water. Either its: 1 mechanical or 2 electrical in
nature.
Mechanical
The easiest to look at is the obvious first. The water is
not falling off the delivery tube? Look inside the freezer. Make sure the
opening of the water delivery tube in back or side of the freezer is open and does
not have ice or frost on it. Ice, here, can freeze and close off the delivery
system. A common problem is lime or scale buildup, causing this ice to form. If
the tube has this problem, defrost it with a hair dryer. Clean the tube with
lime away or CLR. Re try it.
SOURCE: water is freezing in the supply line for the ice maker
This usually means you have a weeping water valve. The water valve doesn't completely shut down after filling the icemaker. This deposits a staedy flow of water which freezes and accumulates in the tube, eventually blocking it off. You would need to replace the water valve which is located at the rear of the refrigerstor. One othe thing to check would be the water supply to the refrig. If the water dispenser is working fine then that isn't an issue. However, if that is flowing slowly you would need to replace the saddle valve which is tapping into your house water supply.
SOURCE: fridge does not keep cold, but freezer is over freezing, icemaker not making ice also.
You should be able hear, and feel the air from, a running fan inside the cabinet, in either side. The common arrangement is having the coils located (behind the wall) in the freezer section and then the fan moves a controlled amount of the frigid air to the refrigerator section via openings located in the rear of the compartment. The vents are normally adjustable so the temperature can be balanced between the two compartments. If there is no noticeable air coming from this vent, then the fan has died.
SOURCE: ice freezes in the freezer in side by side fridge
dec the temp of ur freeze...................or reset your cooling point on defrost
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
repairclinic.com
partsselect.com
directly.
in refrigerator?
refrigerator?
These will help.
Thanks,.
