Go to Settings on your phone turn on device as you start your Bluetooth on your phone. They should find each other and pair automatically but if they don't, turn off the device and then on again then immediately touch "scan" on your Bluetooth setting on your phone. If a new device shows up after scanning under "available devices" touch the new device name and it should pair. Good luck!
SOURCE: connecting bluetooth headset
You have to go through a process to pair the devices.
Firstly:
Make sure bluetooth is turned on on your laptop (varies for each model)
Make sure the headset is fully charged.
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Then goto the bluetooth control panel and select "Look for Devices" or similar. Wait until the device has been found and when it asks for a passkey, enter 0000 and press okay.
see some more info at: http://tinyurl.com/2bz7hc
SOURCE: Motorola H350 doesn't connect...
The issue is with the PS3s compatibility with the H350. Sony should be fixing some of the issues with an update, but from what i've checked online, the H350 is a problematic headset. i just got one as well, and have connection issues with it online.
SOURCE: i have a motorola H350
Sounds like you need to do another method of connecting your phone to your unit, heres the trick..
Most phones have multiple methods of installing your headset, you can either connect it, or activate an existing connection, and last SEARCH.
If you have installed this unit already, all you need to do is ADD another device, when you find your settings for blue tooth, its as simple as TURN ON CONNECTIVITY, and your phone will find the device, if you stored it already on your phone.
Another step is to do a reboot of your headset, hold down the call button until your headset light turns on and turns colors, keep holding the button down 5-10 seconds and you will see it, then try to connect your mobile phone to your unit by SEARCHING for DEVICES in your phone settings.
Last but not least, you can search the internet for the headset, download the PDF and pray that this simple solution can assist you. Motorola's website is very user friendly and has a search engine similar to google or yahoo, register your headset while you are there, because you can get it replaced, exchanged, and have warranties with ALL new units purchased, or if you purchased a used unit from a local store, you still have a limited warranty you can use to get a new or repaired unit.
I hope this helps..
PLEASE RATE ME!
ManOwar
Hello there
The universal pass key that all of these leave the factory with is 0000 (four zeros).
Hope this helps, please don't forget to rate me.
Thanks
