SOURCE: Toshiba Satellite M100
You should upgrade your RAM memory. Check with the owners manual and purchase RAM module. Install the RAM module in the memory slot provided at the bottom of your laptop.
http://www.notebookreview.com/assets/11050.jpg
You should also check the speed of the internet connection you use.
SOURCE: toshiba satellite m100 xp drivers
http://support.toshiba.ca/support/Download/ln_byModel.asp
it's all there
SOURCE: ATI DRIVER FOR TOSHIBA SATELLITE M100
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
SOURCE: i need a infrared driver and a blue tooth driver
(http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1277462&rpn=PSMA0U&modelFilter=M100&selCategory=3&selFamily=1073768663).....................PUT THIS IN YOUR BROWSER AND SELECT WHAT OPERATING SYSTEM YOU HAVE.THERE IS THE DRIVERS YOU NEED.
SOURCE: My toshiba satellite M100 keep turn off, why?
I use a Satellite. They are not heat friendly. Use canned air to blow out the vents on the side & back and blow out the fans on the bottom. Get a cooling fan for under the computer. Try to use it on a firm or hard surface since a soft surface won't allow air flow. Blow it out at least every 2 weeks.
