Hey Earline...It depends on what you are going to do?? Are you flying for the first time? Go directly to the anilines ticket counter... get to the counter at least 2 HOURS EARLY!!! happy flying..
(ps... ask the ticket agent how often do the mechanics change the exhaust jet bearings.. if they don't know - ask for a supervisor..
Replace spark plugs
Replace rotor
Check distributor cap (replace if necessary)
Check timing (adjust if necessary)
Check ignition wires (replace if necessary)
Check ignition performance (firing voltage and ignition patterns)
Check idle speed (adjust if necessary)
Check choke (carbureted engines)
Clean fuel injectors
Check compression and/or power balance (identifies bad fuel injectors as well as compression problems)
Check manifold intake vacuum (reveals exhaust restrictions)
Check battery/charging voltage
Check exhaust emissions (verifies fuel mixture, ignition performance and emissions performance)
Check vehicle computer for trouble codes
Install new air filter
Replace fuel filter
Replace PCV valve
Check all emission controls (EGR valve, air pump, etc.)
Check all vital fluid levels (engine oil, transmission fluid, coolant, brakes, power steering)
Check belts and hoses
Check safety items such as lights, wipers, tires (including inflation pressure), horn, etc.
