Question about Kenwood Dishwashers
I have a Kenwood KID60S15 dishwasher and it is showing an F1 error. Can you please advise how I fix this problem?
  • 1,830 Answers
F 1 is a flood code meaning excess amounts of water have collected on the bottom catch basin.
Posted on Aug 10, 2017
5 Suggested Answers
6ya staff
SOURCE:
paddy 1234
SOURCE: F1 error
help
Posted on Jun 06, 2008
Anonymous
  • 998 Answers
SOURCE: Dishwasher turns on by it self. Gives F1 error
replace control board
Posted on Aug 08, 2009
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: hi ,my dishwasher kenwood kdw4ttsl
Hello, welcome to FixYa.
The E4 error on your dishwasher indicates an overfill has occurred. This can potentially occur due to excessive detergent (accumulitive over time) or mineral deposit in the filters and sump as well.
**Your dishwasher has an overfill protection device which could automatically shut off the inlet valve and starts the drain pump if the water overflows and subsequently display the error. If this occurs, turn off the main water supply before calling a qualified service agent. If there is water in the base pan because of an overfill or small leak, the water should be removed before restarting the dishwasher. This can be done by way of tilting it back (while unplugged of course) and allowing the water to drain from the base**
NOTE: Hard Water conditions will adversely affect wash ability performance of your dishwasher. Hard Water conditions will also contribute to "Lime" (white film substance deposits and/or "Scaling" on the stainless steel surface of the dishwasher tub and "Heater Element" located in the sump underneath the removable filter screen. To assist in minimizing these conditions, it is recommended to periodically operate/rinse the inside of the dishwasher (empty) using 1 cup of white vinegar (at least once a week).
Let me know how this works for you and I'll try to assist you further if necessary. Good luck and thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on May 24, 2011
gopakumarg43
  • 76171 Answers
SOURCE: my fisher and pykel dishwasher is showing F1 error on the screen and beeping and is leaking water how can I fix it
If you wish to get some details; check the site linked here. Pull up older posts.
http://electrotechnician.blogspot.com/
Posted on Aug 09, 2016
I have fisher&paykel dishdrawer and f1 problem. what doew it means;
Hi
Please check this link to troubleshoot your problem in dishwasher if it shows F1 error:-
http://www.ehow.com/how_7307602_troubleshooting-error-fisher-paykel-dishwasher.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Dishwashers
Hello, We have a Fisher & Paykel dishwasher m# dd602 znwn showing After we fixed a hole in the drain line an F1 code still appears and the pump keeps running. What should I do from here?
F1 means that your dishwashers have flooded. You can download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems. If your drawer is noisy you may want to replace the rotors at this time as well.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
Mar 17, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
F1 flashing with a spanner showing
Hi..
F1 code indicates a leak,you will find the water under bottom drawer.Might be the lid probably not sealing well. You have to seal it well properly to fix this error in your dishwasher.
Thank u !!
Jun 17, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
Have Fisher and paykel Nautilus dishwasher showing F1 fault - what does this mean? Dishwasher was leaking water all over the floor dont think major problem as it starting draining when power was reset
f1 means u have a leak where pump and control module is. that is located under sump.the water has activated a flood switch near drain pump. need to find leak to fix problem. make sure power is off to unit b4 looking.please reply to how u go. good luck
Mar 16, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
I'm Not sure of the model number, Fisher & Paykell double draw dishwasher
My dishwasher's doing exactly the same thing. What was the solution?
Apr 30, 2008 | Fisher DD603FCSS Dishwasher
Clearing F1 Fault
Hi, Dexters Dad,
I cannot help you without the make and model of your dishwasher. Please provide this by posting a comment here. I should get a email from Fixya telling me you posted the comment. Thankyou and looking forward to helping you get rid of the F1 error code.
Nov 23, 2007 | Dishwashers
Dishwashers Logo
400 people viewed this question
Top Kenwood Dishwashers Experts
Marvin
Marvin
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
