SOURCE: toro walk behind mower battery will not stay
If the battery won't stay charged it most likely needs to be replaced. Check out http://www.batteryinternational.com/electric-lawn-maintenance-batteries.html . They should have the battery you are looking for.
SOURCE: My Toro GTS walk behind
Hello, I think i can help you.
It appears you have a clogged or partially clogged carburetor". What you can do is tip the mower on it's left
side, remove the air filter and just spray carb cleaner into the
carburetor without removing the carb. It is common for a blade
of grass to get in there and clog it. The pressure from the carb spray
will usually dislodge a blade of grass. Try not to remove air cleaner assembly unless necessary. They can warp
easily and once you remove them, they rarely go back on cleanly ie
without leaking, and you'll need to replace it. Also, if it's not too
dirty, just adding Sea foam to your fuel can be very effective. For the
$10 cost of a can of carb cleaner and a can of Sea foam, this worked for
me. ANother area to check, and cheap to replace, is the spark plug. I automatically ever year, replace spark plug, change oil, put new air filter in ( which you did already) and always make sure you put fresh gas in. Another note; Sometimes it will get a vapor lock where the fuel cap is, loosen some pull a couple times and then tighten down. If your toro has fuel filter , positively replace that.
Conclusion, I believe your problem lies in the carb needs to be cleaned and make sure fuel filter is replaced if this unit has one. Please let me know if this helps, if not we will go from there. Thanks Mike, from Fixya.
SOURCE: Starter rope on walk behind mower is hard to pull
Pull the spark plug out and give it a pull. It should pull VERY easily. You could have a vapor lock inside the cylinder and this will clear it. If it still doesn't pull easily with the plug removed then you've probably either bent the crank shaft or seized the engine, due to a lack of oil in it. Hope this helps. Best of luck.
James
