SOURCE: Need the remote code for LG plasma tV (remote Yamaha RAV202)
On most universal remote control, you will find the procedure to enter the builder code OR a procedure to pass through all the code of the remote, one by one and pass to the other TILL you find the right one.
SOURCE: How do i repair my Plasma TV ?
It's best if you contact a TV specialist to repair it. Once the plasma TV's develop problems, it is no longer a joke. Only thing you can do is send it away for repair. You cannot do it unless you have specific knowledge and special tools besides a soldering iron, pliers and skills. I have an LG Plasma TV. Early last June it had exploded twice. It killed the TV. I sent it away for repair. Then 3 weeks after it got repaired it exploded again. The latest bang was last Sunday (29-6-14), fusing the whole house. I found out why it had happened. I had my Sony Vaio Notepad connected to the TV via an HDMI cable, the same as last time, and the TV made a loud bang. Last time it made a loud bang but didn't fuse out the house, The TV just destroyed itself. This time the TV survived the burnout but fused the house and I was left in the dark to fix the fuses. When I switched the fusebox back on, the TV automatically turned itself on, but I had already removed the notebook. So, I guess Plasma TV's cannot accept HDMI signal from computers. It makes the TV run too hot, as explained by the TV technician but I am not sure. I am still trying to contact LG to question whether this is a possibility that connection of a computer to a TV via a HDMI ports causes the TV to increase its temperature. We are in Winter. perhaps it was my heating system.
You did not say why your TV had malfunctioned. Did you connect a computer or any peripheral that could have upset the TV? If so, prease state what it was connected. It helps understand your case better. So, best bet is to have it repaired by a qualified technician.
SOURCE: How do I fix my Plasma TV ?
Not sure it is a transistor. May be bad caps in fisrs or secondary power supply. contact mfg of transitors to see if yours is transferable.
http://www.utsource.net/30G122.html
I have 30F124 and im a pinoy here in saudi, if you still need for LG plasma contact me on fb.
