SOURCE: IJohn Deere whinning noise
Is the device that lowers or raises the loader a hydraulic piston type device, or more of a hydrostatic type device? Whining noises are not uncommon with hydrostatic devices...
SOURCE: where do fill up hydraulic fluid on a 1490 case
backend by the linkage someware, sory but dont know what oil to use
SOURCE: where do you check hydraulic fluids on a 460 international tractor
I own one. Most have a plug in the top of the trans/hydro case to the left and rear of the gear shift leaver. It takes a 3/4" drive to open it. I use an extention and brake bar or ratchet. The fluid should just all most reach the opening. the books state it should hold 8 to 10 gal. I have found my 460 Utility holds almost 20 gals.
SOURCE: We have an 1961 International
hydraulic fill is on the left side below the gas tank in front of the hydraulic valves square plug oil level 1/2 inch below plug
Hi Benjamin:
I have a fleet of equipment that have hydraulic components, and one of the most regular maintenance tasks is replacing failed or worn components.
Running hydraulic equipment with leaks present is a real safety hazard as the part could fail resulting in hot high pressure fluid being sprayed unrestrained.
Please, do not run the machine until you replace the defective part.
Hopefully there will be a local hydraulic hose shop that can assist you.
Cheers.
