Hello my nikon coolpix b500 camera wont turn on an i have been trying to turning on by changing the batteries, the memory card and the charger but it just wont work.
The B500 is compatible with SDHC and SDXC cards. That means you can use cards from 4GB all the way to the largest cards currently available. (at that time 128GB)
And is it less than 128GB?
Your Nikon Coolpix B500 Digital Camera is compatible with 16GB, 32GB, 64GB and 128GB SD, SDHC and SDXC memory cards.
It flashes green when it is basically on but in a sub mode that I'll call CHARGE MODE. If it is flashing that means the battery is charging. I suggest to let it continue to charge until it stops flashing and then remove the charger connection. When the camera is sitting all by itself with nothing connected you can then turn it on.
At the Time the Camera was made , Nikon lists a number of compatible memory cards. Each year both cameras and cards can read and write data faster. Cheap cards today can be read much faster than written. If any camera can take many photos in a short time, a slow cad will not allow the camera to operate as intended.
The best solution would probably be to check with your seller if it's still under warranty and let him solve the problem, but in case you want to be sure, go through the manual of your camera to see what the lights mean, if you don't have a manual you can find it here: Nikon Coolpix B500 PDF manual download
Possible Solutions.
1. Charge the battery
2. If still not turning on, try using a little alcohol and wiping the battery terminal(s) on the battery and the battery terminals in the camera. Use a QTip and allow to completely dry before recharging the battery or inserting it into the camera.
2. Replace the battery with new one.
3. On/Off switch may be defective on camera. Charger may be defective. Wire connecting power from charger to wall socket may be improperly connected or loose.
Easy. Remove memory card turn on re-charge shut down re-install memory card..... If it does not turn on with memory card removed, connect to charger and turn on
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't
already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Many times when someone fools with a memory card and the camera is on, it sort of backfires when the camera is trying to read or write data to the memory card. Error 10 might be attached to a fault in the memory card or system error. Try doing this first: remove you memory card when the camera is off. Remove you batteries so it can reset. Leave the batteries out for 30 secondsthen replace them. Use a brand new SD memory card and then turn on camera. Go to menu and format the new memory card and see if this helps. Good luck.
