Frigidaire Electrolux p/n 240508049a top freezer model
SOURCE: Freezer defrosts too long.
Outside of HVACRH20 excellent advice, here a few stats about this model. The main control board will monitor the resistance of the evaporator thermistor. This is located near the top of the evaporator. This thermistor determines when the unit goes into and out of defrost. The bi-metal is redundant to the operation. It will terminate the defrost only if the thermistor fails. Check the values of the thermistor with the attached chart. Catriver..post back
SOURCE: Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck [email protected]
SOURCE: Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
SOURCE: We have a Westinghouse WSE6100SA
This could also be an issue with simply too much food in the fridge blocking some of the air channels or that there are containers in there which are uncovered which contribute to high humidity in the box.The unit may also be left open too much.
Before blaming the manufacturer/servicer...let's look at the usage cycle. This ice is coming from somewhere! Do a full defrost of the unit. Keep it closed after loading in food. What is the temperature in the box? 40F in the fridge and 0 F in the freezer is about right. Use an outdoor thermometer and check after an hour of closed door.
