Turn off the power for 30sec. Then turn on the power and the a/c and go to outdoor unit. If you hear a little noise propably will work. If not then unfortunately replace first the eev and then the pc board.
Please give model numbers of both indoor and outdoor units!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
SOURCE: LG air conditioner 24awn error code message Ch 6
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
SOURCE: LG air condotioner with a CH5 error code
CH-05-Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
