Televison & Video Logo
M
Michael Pasqualone Posted on Aug 24, 2017
I have a Toshiba tv, model#46XV640U. Picture takes about three minutes to come on,sound comes on right away. Any suggestions? Thank you,Mike
Gabriel Zamora Paez
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Mar 16, 2019
Gabriel Zamora Paez
Contributor
Level 1:
New Friend:
Answers
20
Questions
Helped
4854
Points
35
Tengo un televisor Toshiba, modelo # 46XV640U. La imagen tarda unos minutos en aparecer, el sonido se activa de inmediato. ¿Alguna sugerencia?
5 Related Answers
Anonymous
  • 432 Answers
  • Posted on Jul 04, 2007
SOURCE: Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Vista Electronics
  • 1694 Answers
  • Posted on Oct 01, 2007
SOURCE: MITSUBISHI VS-4543
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Anonymous
  • 4402 Answers
  • Posted on Dec 11, 2007
SOURCE: Toshiba 43A61 - No Picture, no sound
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
Anonymous
  • Posted on Aug 11, 2008
SOURCE: TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
I have a problem
Anonymous
  • 73 Answers
  • Posted on Mar 23, 2009
SOURCE: Samsung DLP TV, no picture, has sound
Try replacing the ballast next. Its the small circuit board directly underneath the lamp housing. You can access it through the lamp door. If the ballast is overheating or has a leaking capacitor, the tv won't stay lit for more than a minute or two.
Can I watch netflex movies on my Toshiba 46xv640u tv?
I just downloaded the manual from Toshiba and did a search for Netflix and nothing came up. When I googled your model I saw other people complaining that the TV didn't come with Netflix built in. You can download the manual here: 46xv640u om pdf
1helpful
TV Toshiba flat screen
You hv bad capacetor on power board. Just open back of your tv and you will see couple capcetor swelen. They are only couple of dollar each. You just need to know to soder them
1helpful
Is there a picture tube for the Theaterview Toshiba (1996)? The picture sometimes takes more than an hour to emerge. I have to
if you are getting for the first 15 minutes or so lines or noise left to right on the screen that does go away (but is taking longer as time passes) you have a Hyper board failing---Google that for your set.
3answers
1helpful
2answers
Toshiba 62HM195, Loud hum noise when TV is first turned on.
I have the exact TV and had the exact same problems. It is the light engine with color wheel that needs to be replaced, and they are VERY hard to come by for this model. Our repairman has had our TV for 5 months and still cannot locate a vendor that carries the part. He said according to Toshiba, the part has been discontinued. If you happen to find one, please post. I'll do the same.
1helpful
Black line on middle of screen
Hopefully you still have under warrantee. If not, sorry. This line if memory serves me right is because the tv has 2 picture panels on each side of the TV (they join up together to make one picture). Toshiba did not realize that the panels will start slipping thus creating this fine line from the top of the screen to the bottom. They have revamped the newer models and placed glass to adhere the panels together. Even though my TV was under warrantee I got a new one and have had this one for 1/2 year and now the picture just blew (there is sound but no picture.)
Take your TV back if it is under warrantee.
1helpful
2answers
Shakey Picture
bad cap, spray some freeze on it till it comes back and you will find the bad part.
MITSUBISHI VS-4543
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
