SOURCE: Very, very dark (almost black) lcd screen, but is functional
The LCD viewer is made up of the LCD screen, and the backlight. Your backlight is burnt out, or the circuit board isn't sending power to it. Backlights can be replaced separately.
SOURCE: fuji Finex 800 camera
If it's pink/purple and "streaky", you have a bad CCD sensor. The only fix is replacement of the sensor. This is the main image capturing sensor in the camera. The situation is well documented on the web. It's usually the end of the camera, unless it's under warranty (or just a little past). Approaching Fuji's repair department can sometimes yield a sympathetic rep who'll have it fixed at no charge to you. If you are on the hook for the repair, expect to drop about $100 US.
SOURCE: EOS 40D, LCD Won't view only displays taken images and menu
here is Canon's answer;
Issue:
The LCD/Electronic Viewfinder will not display an image or the image is distorted.
Solution:
If all troubleshooting steps have failed, please have your EOS 40D serviced.
Details:
[ Hide ]
Unfortunately,
the issue you describe seems to indicate that your product requires
repair service. Canon has excellent service options and we are eager to
provide any assistance you may need. Links to the service options that
are available for your product are listed below:
Request a Repair Online
You can conveniently pre-arrange repair service with a Canon Factory Service Center through Canon's website.
Find a Service Location
Search to locate a repair service center and obtain further instructions.
If
you still have questions about the issue you are experiencing, a
Technical Support Representative will be happy to answer any question
you may have. You can contact us through the email link or phone
numbers listed below.
We
look forward to helping you rectify the issue you are experiencing and
are always available to provide any assistance you may need.
SOURCE: FUJI FINEPIX F480 GET HANG AND CARD DOES NOT STORE IMAGES
i formatted it in cam only now it's workin good.....dont format in computer it will show this kind of errors
SOURCE: I have a Canon S1 IS which shows a purple image
I have the same problem and after doing research, I found this website.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
I called Canon & they are sending me a prepaid shipping label to fix the camera free of charge! Hope that helps!
