I want to access the HDMI input but the set is locked on TV. How do I do this? when I press input it indicated it is locked
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
SOURCE: Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
SOURCE: TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini. The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz). The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process:
1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application)
2) Connect the Mac to the TV
3) Connect to LogMeIn from another computer (preferrably one where you can see the TV)
4) Go to Applications / System Preferences / Display
5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Note: How to reset video output settings
If you are attempting to change to an HDMI cable from a different video cable or if the video output settings do not match those required for the display in use, the screen may stay black. If the screen stays black for more than 30 seconds, you may need to reset the video output settings of the PS3.
To reset video output settings:
Click below for an interactive video walkthrough on connecting your PS3 to your television or display device (including HDMI).
alt="line drawing of HDMI connection">
alt="line drawing of AC power cord">
