Question about ASUS Computers & Internet
Does A ASUS Transformer Mini have built antivirus protection
Do you need to get antivirus protection for the ASUS Tranformer Mini
  • 260 Answers
Depends on which operating system is installed. WIN10 has defender as part of the OS. Some earlier OS did, some did not have antivirus built in. Look on your list of programs to see if your machine needs a separate AV.
Posted on Dec 25, 2019
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Logitek transformer for force 3D
The power supply is Logitech Model # GAD-SLU-240A8 P/N 190057-1000 OUTPUT IS 24V-----0.75A The output connector is positive center, negative outer ring.
Posted on Dec 13, 2008
Azrael SRL
  • 11800 Answers
SOURCE: what is the output voltage
If the DC is 15v then the AC is around 12v.
Posted on Mar 10, 2011
Christopher Buono
  • 20 Answers
SOURCE: how to connect an asus transformer to a phillips picopix 2055 projector ?
you cant, directly at least... there are no drivers for android to run this projector. since it is only USB, you cannot convert the hdmi to usb...
you could use your computer as a middle man, without hdmi input on your pc there would be video lag and your better off just using your pc.
you could return the picopix you have and get the PPX2480 version, that is brighter and also has hdmi input which you could get a mini-hdmi to hdmi cable and use it directly.
hope that helps
Posted on Feb 28, 2013
The Audio Lab
  • 82 Answers
SOURCE: I need a transformer for my resolv 65a monitor
Are you an experienced tech? In most cases (unless there is a defect in manufacturing) transformers are not a common cause for failure. If it blows the fuse disconnect the secondaries and see if it still blows the fuse. If it does then the transformer is likely the cause, if the fuse doesn't blow then the problem is elsewhere. If you have 120vac at the primary and nothing(or very low) at the secondary(s) then the transformer could also be at fault. If you have done this already and narrowed it down to the transformer, sorry I cannot help. I used service Samson but no longer am able to get parts. Good luck!
Posted on Jan 05, 2015
Testimonial: "Very helpful..I will test again.Not sure I used the proper procedure."
Manual for ASU-T102H-DR-GR
https://www.asus.com/ca-en/2-in-1-PCs/ASUS_Transformer.../HelpDesk_Manual/
  1. Cached
  2. Similar
ASUS Transformer Book T100HA. Overview · Specifications · Gallery ... Description, User's Manual for Simplified Chinese Edition. File Size, 6.83 MBytesupdate ...
Manual & Document - Asus
https://www.asus.com/us/2-in-1-PCs/ASUS_Transformer.../HelpDesk_Manual/
  1. Cached
  2. Similar
There are 3 download servers available on ASUS Download Site - Global, China and P2P. Each server provides exact the same content no matter where you ...
ASUS Transformer Mini T102HA ' 2-in-1 PCs ' ASUS Global
https://www.asus.com/2-in-1-PCs/ASUS-Transformer-Mini-T102HA/
  1. Cached
The ultra-thin, feather-light, 10.1-inch ASUS Transformer Mini is two amazing devices in one! Built from magnesium-aluminum alloy, it's a less-than-800g ...
[PDF]Manuale utente (e-Manual) - Asus
dlcdnet.asus.com/.../ASUS/.../T102HA/0410_I11845_T102HA_V3... - Translate this page Jul 25, 2016 - ASUS Tablet e ASUS Mobile Dock e-Manual. INFORMAZIONI SUL ...... T102H Mobile Dock, H102H Mobile Dock,. R106H Mobile Dock.
asus transformer user manual - YouTube
https://www.youtube.com/watch?v=M33hXCvS4Vc&list=UUy74e...d4uTA...
  1. Cached
Dec 20, 2016 - asus transformer tf101 dock user manual ... asus transformer tf101 keyboard dock manual ... asus transformer pad tf300t owners manual.
Dec 30, 2016 | ASUS Tablets & eReaders
I just bought an asus tranformer book flip tp 500L and can not find the place of the dvd rom?? can anyone help please ???
You could connect the two devices by a network cable (Cat 6 RJ45) and use file sharing, but I prefer to use a USB-to-USB transfer cable, like the one attached. It is USB 3.0 compatible but is still very fast at USB 2.0 speeds.
Michael@fixya
Apr 17, 2015 | ASUS Transformer Book Flip TP500L-UB51T...
How to turn off predictive text from asus tranformer notebook?
To turn off predictive text, go to Settings - Language and Keyboard - Touch Input - Text Input - Prediction.
Then select On or Off - See more at: http://www.phonetipsandtricks.com/tips/samsung-galaxy-note/turn-off-predictive-text-38/#sthash.MPTR2fvE.dpuf
May 08, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
How to connect an asus transformer to a phillips picopix 2055 projector ?
hope that helps
Feb 28, 2013 | ASUS Tablets & eReaders
How do i transfer photos from a usb stick to asus transformer
You need to get the Asus Transformer Keyboard Dock. It has 2 USB port built in.
Buy it here on amazon.
Otherwise you need to a microSD card.
Aug 21, 2011 | ASUS Eee Pad Transformer TF101A1 Tablet...
I have the 600-water Malibu transformer. Some nights one of the loops of lights will go out. The other loop stays lit. I might go out 30 minutes later and both loops are lit. I am still well under the...
Check for a loose connection where the problem "loop" connects at the tranformer.
Also, swap the "loop" connections to the tranformer. If the problem still persists replace the wire run. Sometimes wire gets damaged internally and visual inspection will not reveal that.
If the problem occurs in the other loop after the swap, then you probably have a bad connection inside the transformer. If that is the case, you won't be able to use that connection as the transformer has no user servicable parts.
Also, if the tranformer in under 5 years old, it's still under warranty.
Jul 06, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Transformer burned out
Usually if a tranformer burns out you have a short in the 24v side of the system. What type of system do you have? Most units built within the last 10 yrs should have some type of fuse protection.
Oct 14, 2008 | Heating & Cooling
Oct 02, 2008 | Logitech WingMan Force 3D Joystick
Downloads
Norton 360 has the entire norton protection suite built into it. On top of the firewall, phishing protection, and e-mail protection it also has norton antivirus built right into it. So yes, you have to uninstall antivirus to install 360, but 360 just installs antivirus again. If you ever decide to go back to using just antivirus you can simply redownload it off their web site. Peter
Oct 04, 2007 | Symantec Norton AntiVirus 2004 - (Open...
Computers & Internet Logo
97 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
