SOURCE: fuji s700 taking good moon shots
shutter speed 50 to 80 ISO at 64 get your apature as small as it will go lagest f number set your focus to single point and single focus if you feel comfortable useing manual focus it is better but my manual focus stopped working here is the link to one of my moon shots on flickr
http://farm3.static.flickr.com/2516/3966267384_90afc0b269.jpg
SOURCE: fujifilm instax 200 camera will not spit out pictures! :(
Link
Camera might be damaged because of the fall, suggest to consult the Authorized Dealer near you (-see above link), or send it back to the store where you purchase it as it may be still part of the warranty.
Thank you
SOURCE: I have a Fuji Instax
The same thing happened to me. Make sure that the mechanism arm on the inside that pushes the picture up is connected with the metal piece on the right hand side. The two can come loose allowing the metal piece to not bring the arm with it when you take a picture. Also the roller could have fallen down a bit. From the inside, press the roller up (it will click when it is in the right spot). The roller should be even all the way across and pushed all the way to the top of the camera.
I hope this helps if you haven't been able to fix it already.
(When all else fails, try changing the batteries.)
SOURCE: fuji instax mini 25 film
X-rays can fog many types of film. If you are flying you can declare that you have film, and have them manually inspect it rather than sending it through the x-ray machine.
SOURCE: fuji instax flash is not working
Hi, There is a website at www.PassionGadgets.com which repair those problem in your mini 7s
Don't you mean it won't record an image when you do press the shutter ?
