SOURCE: Mr. Heater Buddy Portable Problems...
ok, your unit must be propane. look on the back where the propane line feeds the nozzle. there should be a very small copper line with two spade connectors on it. this is your millivolt generator line. with a flame at the nozzle the generator makes a very small electrical current which feeds to the main valve and keeps it open. take a piece of wire and jumper these two spade connections together and try lighting the unit again. if it stays on, the hi limit is shot. you can get by with the connections jumped out, you just don't have the safety margin if it were connected. IF with the spade connections jumped out the unit still shuts off, the generator tube needs to be changed.
SOURCE: Mr Buddy Heater Flameup on ignition
It sound like the pivot inside the regulator is damaged. I think that you will need to replace the regulator.
SOURCE: Brand new Hp probook 6540b blank black screen
I have had this. Unplug the laptop, take the battery out and hold the power button for 30 seconds.
HP told me this was caused my "excessive charge on the mainboard"
The above process drains the charge
SOURCE: hayward pool heater h series
It could be that your gas connection has a blockage that is preventing adequate fuel for from getting to the heater. If that is not the case, try consulting your owners manual for these pool heaters. There is an online copy at the link below.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
SOURCE: mr. buddy heater- pilot light goes out when i
would try to replace the thermocoupler for the pilot light and this should cure the problem.
