SOURCE: Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
SOURCE: Smelly washer
I found out the hard way. The GE WCVH6260 fron loading washing machine has a terrible design flaw. There is a 'filter' that sits right in front of the discharge pump. This filter clogs with lint, coins, hair, dollar bills ... etc about every 3-4 months. When it 'clogs', the pump cannot '****' the dirty water through the gunk. As a result, you have nasty, stale water (forever) preventing dirty water from being flushed. What's worse is that since the dirty water cannot leave, you wind up washing/rinsing your 'clean' clothes with dirty water. It is easy to fix.
When looking at the front of your washing machine, there is a rectangular panel at the bottom. Remove the 3 screws (left, right and center) and pull down on the panel. It slides off easy. Right in front of you is a 3" cap. MAKE SURE TO HAVE A LARGE POT TO CATCH THE SLOP BEFORE YOU LOOSEN THE CAP. Remove the cap and pull out. (I took out 'gunk' the size of a tube of racket balls (coins, hair, dollar bills .. etc). You will also see/smell what I mean by 'dirty water'
GE is a bunch of idiots. We have only had our machine 12 months. This is obviously 'regular maintenance' kind of stuff (kind of like periodically cleaning the lint filter on the washing machine) and GE doesn't even make the 3" cap accessible from the outside. I checked the manual and these problems are not even FAQ's in the manual:
* machine 'pauses' between every cycle (push start to continue)
* clothes smell musty
* water doesn't drain
* cycles (consistently) take longer than timer says
* clothes still soaking wet even after spin cycle ... etc)
SOURCE: terrible mildew type smell
Water forms in the Bellows it is a rubber boot between the door the drum.. clean this out real well ..To prevent this in the future leave the door cracked open when you are done using the machine to allow it to dry out.
SOURCE: Maytag Neptune/ clothes smell like mildew
Go out and buy a box of "AFFRESH". Run it according to the directions.
SOURCE: how do I get rid of mildew smell in Siemens UltraSense front-load
After your last wash for the day, wipe the water from the rubber door gasket and leave the door propped open between washes. I usually stick a folded up washcloth in the top of the door frame at the hinge to make sure no one closes the door. This is a problem with all front loaders.
