SOURCE: refridgerator top freezer exterior wall hot
Hi.........
Folow these steps. It's worth a try.
1.Pull
the fridge out from the wall and unplug it.
2. Clean the dust and lint off
the compresser and everything else.
3. Also clean under the fridge.
4. The
frame around the freezer door should cool down.
If the cooling fan was stuck , that may also be a cause for your refrigerator wall becoming hot.Check that too.
Hope My info is useful....Bye
SOURCE: Model FCD-123 Frigidaire malfunction
2 possible issues .evaporator fan motor is not working.you should be able to hear it in freezer.auto defrost is not working and vents are clogged with ice.look for ice/frost buildup on freezer wall///floor
SOURCE: need dimensions width & height
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
SOURCE: What is the inside capacity for Kenmore Elite electric dryer, model # 11062062100?
It might be rated by weight- pounds for example.
