SOURCE: HELP FINDING A CARD TO FIT MY PCI SLOT
It is easy to get the PCI & PCIE stuff mixed up. PCI slots are all white doesn't matter who makes the board. PCIE however is all together different from a PCI slot. The PCIE slot sits fauther away from the back of the computer & so does a AGP. PCIE is a very long card. A PCI is not. The short slot you saw is also a PCIE slots. Not for video but more likely for network card. Most people never use them. Most likely the long slot above the short slot is a PCIE. So you want a card that is like what I'm going to list in this link.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1559&Nav=|c:1558|&Sort=0&Recs=10
Please list the model number of your Dell & I can tell you exactly what video card you need.
please vote... I'll check back in an hour or two.
SOURCE: I cannot insert a CD into the CD slot.
I really like these radios, by the way, and have 1 of the radios w/out CD, 2 with the CD and one of the HD radio's. I'm one of those people that needs multiple alarms to get up so I set several of them to turn on at different times in the morning and it works great!
I have had this problem twice and I've unplugged the unit then after I plug it back in I hold down the CD eject button while I turn it back on. The display then says something like "CD Reset" and it resets the CD mechanism to the beginning of the cycle. This moves the CD holder to the correct position. (I assume the problem is due to the CD positioning device stopping in the wrong place after it ejects a CD, for whatever reason)
I hope this helps. Mine did the same thing with no CD inside.
I listen to the radio a lot, and by having these in several rooms, I can listen to radio without having to have it turned up super loud when I am walking around the house. I also use this at the High School where I am a science teacher. It produces enough quality audio to fill the classrooms with music or playing podcasts of "Science Friday."
SOURCE: remove a cd that won't eject from a dell 1530 slot
There is a button (one of the touch sensitives ones up by the power button. You have to press it over and over and over again till it comes out! f that doesnt work then completely turn off the system and before it gets to where you put in yor password (anywhere after you press the power button just nt password place) and then it should pop out!
HTH! =D
SOURCE: How to insert SD memory card into card rader in laptop computer
I would like to inform you that Acer's laptop doesn't support all kinds SD memory cards available in local market. Its not compatible with all physical dimensions of various memory card companies. So in that case you need to use EXTERNAL Memory card reader which is attachable to USB ports.
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
SOURCE: Hello, I cannot find the second memory slot
there is only 1 slot under the bottom cover, the other is under the keyboad
2 nd slot from the top if your computer has a cd / dvd drive
hope this helps
