Yes.
All it takes is time.
Feel free to ask away, and hopefully someone will get back to you with a proper answer, or at least point you in the right direction.
Cheers from NZ
hese models are equipped with two filters the main filter is located under the vehicle adjacent to fuel tank and an auxiliary filter in the engine compartment
As paid experts we are required to answer 150 free questions a month,I think everyone is able to ask some amount of questions for free.Although I dont think you can live chat or phone chat for free.So do you have a question you would like to ask?This is a free message and my answer will be also.
Alternator does not usually cause engine to run rough. You can test the alternator with a voltmeter, if you have one. Measure voltage at the battery with engine running (jumper cables removed). Voltage should be 14-15 VDC. If you don't have a voltmeter, take the alternator off and have it tested at the parts store. Most stores will test for free before selling you a new one.
If the check engine light is on, you might also ask the parts store to scan the OBD II port for trouble codes. hese may tell a bigger story, especially is fixing the alternator is not the cause of roughness.
ON MOST PC ON FIRST SCREEN U NEED TO HIT ALT F10 OR 11 DEPENDING ON MACHINE.IF IT DOES NOT WORK THEN YOU HAVE NO PARTITION FOR THE RESTORE AND THEREFORE HAVE TO HAVE THE DISK.USE A FRIENDS PCBURN ALL YOUR DRIVERS TO A CD AND OUT LINEX FREE ON IT OR BY A NEW DISK SORRY 4 CAPS STUCK ON ME. YOU CAN GO INTOMY COMPUTER IF U CAN AND SEE IF THERE IS A SECOND PARTITION IS THERE.CAN U DO ANYTHING WITH THE PC
You could try hese two but there not for you specific model. There the closest models to yours i could find codes for. I hope they work fo you. If they don't loo on dvd365.net for another code closeset to your model.
1. Turn on 2. Open the tray 3. Press 0000 in RC 4. Change to any region you want 0 for region free 5. Press Pause 6. Turn off 7. Turn on again and enjoy
Primero con el buscador google poner driver canon pixma mp160 y de ahi hay que bajarlo , despues ejecutar el archivo en tu computadora, esa es la mejor manera
