SOURCE: Hoover nextra 5+5 washer dryer HNWF 3135 heating broken
it is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop. for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
SOURCE: hoover six express wdm130 1300 washer dryer
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
SOURCE: Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
SOURCE: dryer sensor keeps tripping dryer does not heat up
Have you tried replacing the sensor? Would you like a manual?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
