Electrical Supplies Logo
David Ubach Posted on Sep 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i jump start a valsi 7500 watt generator with a car battery if the car is not running?
richie46
Level 3:
Top Expert:
  • Master 12,962 Answers
  • Posted on Sep 04, 2017
richie46
Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2941630
Points
58151
If battery good, why not. Just hook up correctly!
5 Related Answers
Anonymous
  • 18 Answers
  • Posted on Sep 19, 2008
SOURCE: Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
boeing46
  • 7 Answers
  • Posted on Jun 13, 2009
SOURCE: VALSI 5,500 WATT GENERATOR WILL NOT START
All generators need to be run once a month. All things from the tank to the and including the carb will get gummed up with dried out fuel. I have a whole house generator and a 5500 watt gen set on my motor home. I keep fresh fuel in the stand alone house generator in California in case of a bad earthquake. I drain the gas after every run and keep all vehicles full of fuel just in case. Run gen sets at least once a month or pay pay pay!!
Anonymous
  • 57 Answers
  • Posted on Jul 29, 2009
SOURCE: Valsi Generator 7500W no output voltage
If its a Generac could be the voltage regulator or control board. If you want to go inside then disconnect the avr (voltage regulator) from the field and put 12 volts to the field slip rings with a car battery. Watch Polarity.... Yu should get about 60-80 volts out of the 115 receptacle. Plug in a light bulb and see if it lights. If it does then the field and stator are probably ok and you need to look elseware. Make sure breakers and connections are ok from the stator and receptacle.
protek480
Craig Butler
  • 1730 Answers
  • Posted on Sep 11, 2009
SOURCE: no output voltage at all
The generator needs to be 'flashed' to bring back the excitation for output. Is this something you can do? Let me know and I can help you...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Anonymous
  • Posted on Sep 30, 2009
SOURCE: My Troy-bilt generator will not generate watts
I have a Troy bilt 7800 13500 generator. It has maybe 40 hrs on it. And It stopped working. I took it into a shop to have it fixed. Repair cost would be $1000.00 I paid 1200 for it. Shop said the 3 main parts of the generator were fried. The Generator was bought in 2005 and only like 40 hrs on it and it is dead. Troy bilt will not help out with the repair because it is to old, yet it has no real run time on it. Now the generator is just a paper weigh
I have a valsi 7500 watts generator 13.5 hp OHV robin engine. EH41D 1002306. i need a new caburetor for it. can you help me in this matter with a parts number for the carburetor.
contact the maker,
ask them,
or buy one off ebay, using facts above
there is no other way. (there is a parts list at most makers web sites,Valsi
omg first google hit.
http://www.valsi.com.mx/
Is there a Auto shut off switch/elect overload that would prevent a Valsi 7500 13hp generator to start?
yes
it is called a low oil warning module and prevents spark if the sump oil level is too low for safe operation
My 7500 watt generator doesn't produce any power
If it has sat, it may have lost it's rotor residual magnetism. Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged. If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
Troy bilt generator
pull the carby down and clean out the corrosion blocking the main jet
We have a Valsi 5500 watt generator that isn't putting enough voltage out to run everything in out small travel trailer. It runs the lights but doesnt push out enough voltage to carry the A/C, microwave,...
How long have you had this generator?
Has the generator worked on all of these loads before?
Model 5500 is a 5500 Watt generator which could easily be 5500 watts (Peak) and not continuous.
Your AC is an inductive load.
Your lights are resistive loads
An inductive load can cause issues when starting due to an increased current demand at start up that some generators cringe under. Do the lights flicker or are they stable? I'd say your diodes on your stator are working if you have light stability but you haven't provided nearly enough information for a detailed solution.
I'm sure you have enough voltage but you aren't getting enough current to run specific loads. How many watts is your AC? How many watts for your microwave? Both of these units demand a great deal of energy to run and when you place too much demand on your generator, it will choke it out and eventually, will cause damage to the generator. You may consider getting a beefier generator with a greater amount of wattage output.
Seeing these specs online and noting what you are trying to run, you have an undersized generator and need to get one that can produce a greater amount of running wattage (as well as peak wattage).
2answers
I have a valsi 7500 watt 13 hp with tecumseh enduro xl/c engine-its extremely loud and wouldn't stay cranked. My ex - an ''idiot'' worked on it without my knowledge - we now have lines that we don't know...
Valsi 7500 watts/13hp tecumsa engine. Was running fine and then started surging like it was going to die and then it ran out of gas. Put fuel in it and now it wont start. Gets fire and has plenty of gas. Problem???
3helpful
2answers
8helpful
5answers
Top Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
