Televison & Video Logo
Nancy Nixon Posted on Sep 04, 2017
I have inherited a Westinghouse flat screen tv SK-26H640G model. It will not receive a signal via our coax cable.
It works fine with the DVD /vga input. It is not the cable that is at fault. Can anyone help?
2 Related Answers
Anonymous
  • 120 Answers
  • Posted on Apr 07, 2010
SOURCE: Westinghouse sk-32h540s TV, VGA input, image can't center.
Hello, two things, one try using the TV with the native resolution of 1366 X 768, and secondly try updating your video card. If you are not having this issue with the TV on the other inputs than most likely it is a settings issue with the laptop. Please rate this comment if it was helpful.
Anonymous
  • 14553 Answers
  • Posted on May 17, 2012
SOURCE: trying to hook up flat screen to my computer?
May or may not be compatible---try what connections the set has to see---the owner manual for the set should have the info you need.
Where can I buy a replacement base for a LCD TV SK-26H640G
Knowing the Westinghouse brand can be hard or impossible to get things from try to Google the model number for base or pedestal base etc.
Trying to hook up flat screen to my computer?
What do I do to get my signal back on my westinghouse TV that is hooked up to dish cable
If no signal via the cable fitting try hooking set via one of the sets of jacks on the back (audio/video or component) to see if coax input or tuner is bad.
If the set works with a DVD etc hooked to one of those inputs and your cable is good--maybe a bad tuner in the set---also if using a box try hooking cable direct to set to rule out the box.
It is a 42" Westinghouse SK32H520S and it worked
It is probably a poor connection through the coax. I would replace the coax and that may resolve the issue.
1helpful
Can't get my westinghouse tv to recognize dish network
Happy to help get that fixed right away!
You mentioned that your TV is not recognizing the DISH Network signal, since wedo not know how many TV's your receiver is able to support, or whether it's theTV1 or TV2 having the issue I will address them both.
The first thing we want to do is ensure that all connected components arepowered on (VCR, DVD Player, etc.). Check what channel or input your TV iscurrently on by powering the TV off then back on and noting the channel orinput that appears on screen when the TV is powered on.
If TV1:
Check what type of cable is used to connect the TV to the receiver. If you areusing a Coax Cable to connect the receiver to TV1, check the receiver'sback panel for the output name. If your receiver has a "TV CH 3/4Out" (non-ViP Receiver): Tune TV to channel 3 or channel 4,if it has "Home Distribution" output (ViP Receiver): Tune TVto channel 62 or 75. If using non-Coax (RCA, Component, orHDMI) to connect receiver to TV1, cycle through the inputs until pictureappears; most TVs have a "TV/Video", "Input", or"Source" button. If the issue persists, check that theconnections between your DISH receiver and your TV are secure then reset thereceiver by unplugging it from the outlet for 10 seconds then plugging it backin. If not fixed then connect another component (VCR, DVD Player, etc.) to thesame TV, using same cable, same input, and same channel to see if it works. Ifit works with the other component then call us at 1-800-333-DISH (3474) foradditional troubleshooting, if it still doesn't work with the other componentthen the cable should be replaced.
If TV2:
Access "Modulator Setup" from TV1 by pressing the menu button(on the top left of DISH remote) then pressing the numbers 6-1-5. Tune TV2 tothe channel that appears under "TV2 Out" on screen. If stillno picture, verify the mode (air or cable) that TV2 is on. Then change themodulator setup to match this mode (air or cable). After changing modulatorsetup, tune TV2 to the channel that appears under "TV2 Out" onscreen. Check that the connections between your DISH receiver and your TV aresecure then reset the receiver by unplugging it from the outlet for 10 secondsthen plugging it back in. If not fixed then connect another component (VCR, DVDPlayer, etc.) to the same TV, using same cable, same input, and same channel tosee if it works. If it works with the other component then call us at1-800-333-DISH (3474) for additional troubleshooting, if it still doesn't workwith the other component then the cable should be replaced.
Phillip Chang
DISH Network Customer Service Representative
I own a SK-32H240S westinghouse - I am trying to find the channel to where a valid signal can be found - In these channels I surf, all i get tis the "no channel" message - I have DISH NETWORK and am trying...
We would be happy to help get that fixed right away. Thefirst thing we want to ensure is that all connected equipment is on. Check whattype of cable is used to connect the TV to the receiver. If you are using a CoaxCable to connect the receiver to TV1, check the receiver's back panel forthe output name. If your receiver has a "TV CH 3/4 Out" (non-ViPReceiver): Tune TV to channel 3 or channel 4, back if it islabeled "Home Distribution" (ViP Receiver): Tune TV to channel62 or 75. If using non-Coax (RCA, Component, or HDMI) toconnect receiver to TV1, cycle through the inputs until picture appears; MostTVs have a "TV/Video", "Input", or "Source" button.We want to ensure that the TV and the receiver are connected properly, pleasevisit this link to for more information:http://www.dishnetwork.com/SupportSection/setup-receiver-totv. Once we havemade sure everything is connected properly, unplug receiver for 10 seconds thenplug it back in, this will reset the receiver. If we are still not getting apicture connect another component (VCR, DVD Player, etc.) to the same TV, usingsame cable, same input, and same channel to see if it works. If you get apicture with the other component give us a call at 1-800-333-DISH (3474) forsome additional troubleshooting. If it doesn't work with the other componentthen replace the cable that was used.
We hope these steps resolve the issue. We want to thank you for being a valuedDISH Network customer!
Phillip Chang
2helpful
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Home theater hook up
Make sure u have plugged in the audio cable to the tv.
thanks..
Onkyo TX SR 606 -- Connection Issues with Cable/ Dig Coax Audio
1. Video-out to TV: You should be able to connect the receiver to the TV with any / all of the available video modes.
However, if you don't have the HDMI connection, then the Video-In on the TV would have to be switched back-n-forth between Composite / S-Video, depending on how each device is connected to the receiver. [If the TV has 'auto-sensing' Video-In then it should automatically detect the incoming signal from the receiver whether S-Video or Composite or Component.]
2. Audio-Input to receiver: As the receiver provides only two Coax-Inputs, you would have to first assign Coax-1 to DVD and Coax-2 to Cable. Then connect the coax cables accordingly; that should do the trick and allow you to hear the cable sound over coax.
If you still have a problem then check the 'Input mode' setting; leaving it on Coax-1/2 (Auto) would be the better option. This is on pg. 50 of my manual "Specifying the Digital Signal Format".
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
