SOURCE: code for Sony tv
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: register hend set to base
Try the procedure on page 62 of the following PDF, and post your results.
http://www.conversationpiece.ie/download/KXTCD505.pdf
SOURCE: How to program the Sharp XE-A12 cash register
here is a link to the software.
there is not enough space here to type instructions, its 90 pages long.
you will need a sd card or usb cable to connect to your puter.
http://www.sharp.ca/downloads/default2.asp
SOURCE: How do I get to the place where I can see my 5 digit code on the TV to register with Amazon Prime?
go online to register it
