1) Turn machine off using the on/off switch on the front of the machine (not at the power socket)
2) Press spin / temperature / cleaning action button together until the display on the machine activates (the current language selected should be flashing)
3) The spin / temperature buttons can be used to scroll up / down through the language options.
4) When you reach the desired language press the cleaning action button to confirm your selected language.
SOURCE: CHANGING PRINTER CONTROL PANEL LANGUAGE
See solution below:
1. Turn off the printer.
2. Press 'select' and turn on the printer. (select button should be pressed while turning it on)
3. press '-value+' to choose your language
4. press 'select' to save
5. press 'go' to return to ready mode.
Thanks
SOURCE: Sansa Express change language to English
in the settings.....ie the one that looks like a equaliser......
go to the option above FM....in whatever language u can see ...the FM is written in english. that option is the language setting.
Thanx
SOURCE: How do I change from Spanish to English on Motorola RAZR V3 Cell?
Just go to Meniu principal (main meniu) select Configuración (settings) click SELECCIONAR (select) then scroll down to CONFIGURACIóN INICIAL (initial setup) click SELECCIONAR (select) again and then scroll down to IDIOMA (language) and from there select english, thats it.(Or just go to the Motorola web site and download the full manual and used icons shown there to get where you wanted to go. )
SOURCE: please could you tell me how you change language
touch menu icon @ display screen bottom right, enter settings with an icon like a blue circular saw, enter phone settings with phone icon on the left (item 4 in the menu). Language is the first item there, enter it and select english then save. good luck
