The text colors on my screen are green and I want to change the color.
SOURCE: sony kd 34xs955 green color in corner of screen
Check whether you kept any magnetic material nearby the tv recently, keep away . If not you will not switchoff the Total power for the past 3 or more days. What i mentioned is correct switch off the tv total power and wait for 15-30 mins and switch on. The problem is fixed.
SOURCE: screen lookes like colores separating
Hey try this check under setup do you have the convergence option. if you do not you may have a simple little repair. Check out the article in the tips and trick section of this site intilted "the fl231 problem"
SOURCE: help! the green light flashes then nothing happens
I opened the transformer up, and found a lot of corrosion on the board, creating a short circuit between tracks. This corrosion was caused by poor workmanship in the manufacture. This board never had the fluxes cleaned off after soldering. I will be contacting Western Digital and requesting a replacement transformer. I suggest everybody with this problem should do the same.
SOURCE: works but prdominantly green, can't ajust with color controls
The lcd polerizer(not sure this is proper name ) is bad.It has three: red,green,blue and one of them is bad. I also have a similar issue but only on the left side. Took it apart and found the bad one.
SOURCE: red and green colors on screen. 3d like effect?
Your symptom sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
I would recommend a low wattage soldering iron (45 watt) available at Radio Shack.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
Here is the part number for the kit, TV-KIT-2014 Price: $76.95 + $6.95 Shipping
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
