SOURCE: samsung gleam
This is a software problem. Remove and re-insert the battery which resets the microphone. Samsung does not have other solutions.
[email protected]
SOURCE: Samsung Blackjack II people can't hear talking on the phone
Hi jobare,
If you haven't already tried it, you may want to try a hard reset. (Warning: the hard reset process will erase all content and settings that you've added to or created on the phone.)
Hard Reset for BlackJack II:
1) Power off the BlackJack II
2) Hold the UP button on the directional pad
3) While holding the UP button, press and hold the Power button
4) When prompted, press the 1 (or 'E') key to continue
5) When prompted, press the 'Y' key to confirm
If this doesn't resolve the audio issue it's probably microphone related and you'll probably want to research replacement options.
Hope this helps!
Thanks,
The MoDev Kid
SOURCE: Brand new Samsung Sch-U340.Noone can hear me and i cant hear them
Try dialing *22899 and press send.
If that doesn't auto update the phone (you will see on the screen if it does) try *22899# and press send.
Try call again.
SOURCE: I cant hear anyone talking on my iphone
This sounds like the earpiece has gone, you should be able to hear them if you put it on loud speaker or if you are using bluetooth. However as it is only 5 months old it is covered under warranty so my advice would be to take it back to where you bought it or contact apple direct. They will repair it for you however you will be without a phone for a number of weeks
SOURCE: phone line won't hang up
I would check the DSL filters. Your phone should not interfere with the DSL. Make sure there is a filter on any line going into your phones. If there is a filter replace it and see if that works. Also, check other equipment on the line, fax, computer, credit card machine. They will need filters from the DSL too. Remove these other devices and check the line for the problem then add them back one at a time.
