SOURCE: Bally coin slot machine wont let the handle pull
THIS IS DOCTOR FIX. MY BUSINESS IS GAMING REPAIR. (JUKE BOX=PINBALL= SLOT MACHINES
BOWLING =POKER, FOR 68 YEARS.) IF YOU HAVE NOT SOLVED YOU PROBLEM, I ASSUME IT IS ELECTRONIC, NOT MECHANICAL. IF MECHANICAL , LET ME KNOW, I WILL TELL YOU WHAT TO DO.
ON THE ELECTRONIC, OR ELECTRIC (NO COMPUTER)
THERE IS A BAR MOVES ON TO THE CAM ON TOP OF THE CATCH, ABOUT 3 INCHES ABOVE THE BOLT THAT HOLDS THE ARM IN PLACE, WHEN A COIN IS INSERTED INTO THE COIN SHOOT, THAT METAL BAR ENGAGES THE RATCHET , TO SPIN THE WHEELS. DOES THAT HAPPEN ON YOUR SLOT.? OPEN THE DOOR PULL THE WHITE SWITCH THAT CLOSE WHEN DOOR IS CLOSED (OUT) THESE ARE A THREE POSITION SWITCH.
IN-HOME JUKE BOX REPAIR
[email protected]
HOPE IT HELPS.
