Not a fix, but interesting.
I have found that the built in win10 image viewer will sometimes do this, even if, as you have done, I rotate and save the images!
There may be some data in the EXIF info doing this? I can't find the images right now to check as they are on a PC at work (work related!)
I fixed it by using a "real" image viewer ;)
Does your camera have the ability to invert images when the camera is rotated? Just clutching at straws.
SOURCE: Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector.
Navigate to the \DCIM\100Frame directory and delete all the Phillips
advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look
for Image Resizer in the right column). After installing it, "Select
All" pictures in the directory you created, then right click and select
"Resize Pictures" from the context menu. Choose the 640x400 radio
button. Sort by size and copy all the small ones into the
"\DCIM\100Frame" directory on the frame drive (Called Removable Disk on
my PC).
SOURCE: screen reading memory card not initialized
I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
SOURCE: Saving photos to internal memory on ultech digital photo frame
go to http://camera.manualsonline.com/ex/thread/view/idthread/1339017
lots of good instructions, I got mine working already
SOURCE: hello, is there a way
You will need a card adapter for whatever card is in the digital frame. Then just use the adapter with the card and you can save the pictures onto your computer. Adapters are usually no more than 10 dollars and local stores.
SOURCE: PF-A700B Digital Picture Frame: Hi i have a Mustek PF-A702B digital photo frame an...
have you tried formating your SD card to FAT32 format?
Turn the frame up the other way.
Thought of that but I use the frame on a table and the stand won't reverse.
Maybe use image editing software on computer to save images upside down ? Sounds a bit clunky, I know, but I don't think any frame has the ability to save inverted images, even if it will display them.
I have done this and to my amazement and confusion the frame still displayed the images upside down!!!! I just erased the card and recopied the images from my computer, even on to a different card and again no change. The really strange thing is that some of the images display correctly (say about 15 out of 60). Further, I have used the frame in this manner many times before without ever seeing anything like this. I am about ready to give up.
