SOURCE: Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
SOURCE: aiwa nsx-9000 is eating my tapes
Well 1st unplug it then you can start by qtip cleaning, blowing internal maintenance service. But for the most part regardless of use or age whenever there is gears, bands moving parts which in time get worn, Now this is were keeping clean extends life, So time to shop for a new 1 because repairs and part availablity exceeds the value,of your problem
SOURCE: Red light above display flashes but no functions working
hi Dave
I'm not the most technical person in the world but I think I've fixed mine which had the same problem this afternoon, which is how I came to find your message!
Right.. here's what I did. It would appear that you have some kinda mechanism jam (even if there's no disc in it), so... please excuse my non-techie terminology throughout.
By the way, I probably don't need to tell you this but unplug the unit from the mains first or you might light up if you touch something!
Working with the unit facing you (control side), remove the two small screws at the back (on the metal flange) and two medium screws from the right hand and left hand sides of the main casing, then slide it off from front to back so that you can see inside the recorder. If you look in and down at the CD tray transport mechanism you should see a white plastic 'cog' wheel on the left hand side of the unit near the bottom 'floor' of the machine. Carefully rotate this wheel with a finger CLOCKWISE (pushing the wheel from front to back), slowly and gently - don't force it - and you should see the CD tray mechanism and gubbins start to move; keep rotating until the tray comes right out, or as far as you think it goes. Then, plug the unit back in, and switch on - the tray SHOULD then be taken back into the machine, the red light will flash, and the display should come on. As I say, mine has, so try it and I hope it works for you!
All the best (we'll beat these damn machines yet!)
Kev
SOURCE: My Emerson stereo MS9903TTC won't turn on. It was
I had the same problem the power button is pushed in. You did not mention if your unit came with a remote control if it did use that to turn your stero on and off. you will not be albe to use any of the buttons on the stereo if the controls are listed on the remote IE; Cd player, radio tape or tuner. try this please. hope this helps
SOURCE: The tuner, tape player, and cd won't work and the
protect means, service mode, or in other brand it's says f16, the only solution to fix that problem is to bring it into jvc service center
