There is a special lubricant spray for treadmills that you spray. injection pump. The air injection pump is designed with a check valve inside which only allows air to flow in one direction, preventing exhaust gases from escaping through the air pump and only allowing air to enter. When this check valve fails, moisture is able to get inside the air pump. Make sure you don't have dirt and dust build-up before spraying.
Dear Sir:
Please see the diagram attached from REED switch, adjust, clean, and tight the connector wires very well.
2) change the batteries by new ones, use the best.clean the contact batteries.
3) tight the ribbon cable from keypad .+ tight the connector from display board vs lower board.
4) after you fix it RUN THE sofware calibration for diagnose, troubleshooting, See my personal tips for help
sincerely. God bless you
