SOURCE: my ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
SOURCE: How do I disable my private browsing on my apple ipad mini
Why you want to disable it? You can use apps. Whenever you didn't want to use it, just turn off. LEO Privacy Applock Hide Safe Android Apps on Google Play
All of the Ipad interface is done through i-tunes. You have to connect there to do the setup or retrieve your setup. It doesn't seem to make sense, but that is the way Apple does it.
SOURCE: my ipad is saying apple id disabled,how do I get it un disabled?
How To Resolve The Apple ID Locked Or Disabled Issue?
Well, if someone unfortunately tries to hack into the user's Apple account by entering the password incorrectly infinite times, or even giving various wrong answers to your security questions, Apple will further easily recognize the attack and will entirely lock your Apple ID. As researched by Mac technical support team, it's a good sign because it signifies that an attacker can't anyway gain access to the user's Apple ID to avoid allowing them get into a user's iCloud email, iMessages as well as FaceTime. However, it may often happen that it's not a hacker who is trying to get access to your account, sometimes it's only we who is getting ourself locked out of the account because we have forgotten the password.
Solutions to resolve the "Apple ID Locked Or Disabled Issue.
Solution1: Unlock the Apple ID
Whatever the reason for Apple's disabling the account is, there is every possibility to get back into it. One simply needs to follow all these below mentioned tricks to recover their account and create a new password.
Solution2: This phase is based on the security process
·If you are working with the set up two-factor authentication then it is quite possible for users to receive a code on a trusted device or as a text message on the phone. Users are required to enter the verification code before unlocking their account and changing the password.
·If anyone is working with older two-step verification process, then a recovery key is needed that was sent to them while setting up two-step verification process in addition to a code sent to a trusted device.
·Well, if a user haven't set up either of the above methods for security purposes then one needs to unlock the account by using their password, or simply has to answer few provided security questions at the some point.
Fix your Mac issues with expert team working at Mac customer support Toll-Free 1-800-213-8289 department and get all your headache resolved at a go.
Hi cliff ferreira, I want to help you with your question, but I need more information from you. Can you please add details on what is disabled in the comment box?
For example:
1. Does your iPad power up? Is the iPad fully charged?
2. Will it not accept your login code?
3. What model is your iPad?
