I am an older woman I do not know a lot about modems and electronics. So I plugged in to USB port.Also have tried the HDMI port.I have a HDMI cable. So where do I go from here?
SOURCE: Pink Screen on Vizio 37 inch with HDMI Connection
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
SOURCE: vizio tv
This is the price you pay for using something expensive and and complex without fully understanding its properties.
Dharmic law will RROD my Xbox or something, don't get too angry.
SOURCE: Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
SOURCE: LG HDMI problem
have you found the solution for this problem because i have the some problem with my tv??
