Hello, I hope this link can help you out. It is a zte website which gives a tutorial on how top use the mobile device.
It does explain on how to get the upper case letter.
Send an SMS Tutorial
SOURCE: phone says "No connection"
Are you sure the phone's internal batteries are charged? Some phones can be put on their base backward, which prevents them from charging.
Look for an indicator light that tells you the phone is "on charge" when it's sitting on its base.
Does the phone ring when a call is coming in?
SOURCE: sony ericsson phone lock reset code (UK)
take the phone to a mobile service center and have the code reset
SOURCE: My Mo's shower is about 6 years old. I think the
Sure - there is always help at FixYa!
This sounds like a bad cartridge. They can be replaced. To replace the cartridge:
Turn off the water to the tub/shower.
Remove the handle cover (it should pop off)
Remove the center screw (usually phillips head)
Remove the retaining clip holding cartridge in - you can use a pair of long nose piers or a small screwdriver
Grab the cartridge with a pair of pliers and pull straight out. It may require a little force - there are O-rings around the cartridge to keep it from leaking.
Check the cartridge bore (the hole where the cartridge was removed)
Clean any debris or scale - lime away or CLR will work
Apply a little bit of soap around the new cartridge to help it slide in easier. Push it all the way in and make sure it is seated. Re-install the clip (you should have received a new clip with the replacement cartridge)
Turn the water back on a check for leaks
If OK, reinstall the knob screw, and cap.
Let Mom take her warm shower...:)
Testimonial: "Thank you very much. I will try my Nursing expertise at fixing this plumbing problem, darn economy I wish I could afford to hire a plumber. Thanks. "
SOURCE: disable do not disturb feature
my PC starts up in the night when unconnected attempting to update,how can I desable this operation?
SOURCE: bought a blackberry pearl flip off ebay, got it
Hi there, Open up the phone application, hit the blackberry button (to the left of the ball) and go to Options. From there, look for "smart dialing" - click on that one. In there, look for Conutry Code and Area code - make sure that area code is empty and the country code is the correct one for your country. The number length should also be changed to match. Hit the blackberry button again when done, and save. You should be all good now! Alex
Testimonial: "this solution worked, i had to change country code to +44 for uk and it worked. thank you for all your help. xx"
