The fans can work in the intelligent mode or forcible mode.
In the intelligent mode, the fans start to operate only when the ambient temperature goes higher than a specified value. In V200R003C00 and later versions, you can run the display fan speed-adjust threshold minus command on the switches that use the intelligent heat dissipation mode to view the temperature thresholds for the fans to start and stop running. The set fan speed-adjust threshold minus command can be used to lower these temperature thresholds.
Intelligent heat dissipation:
• Huawei S5700-24TP-SI-AC
• Huawei S5700-24TP-SI-DC
• Huawei S5700-48TP-SI-AC
• Huawei S5700-48TP-SI-DC
SOURCE: How to Configure Rate Limit on Huawei Switch
It's different from configuring rate limit for Huawei S6700 and other Huawei Swithes. The article as below may help you for your question
Huawei Networking Products News and FAQ
SOURCE: Does 350W AC power module of Huawei S6700 Series Switch is the same as Huawei S5700 Series Switch?
No, Huawei S6700 Series Switches don't have PAC-350WA-B, it only apply to Huawei S5710-HI series switches.
