Hello and good day, I just bought a digiland 8 tablet DL808W. Tried turning it on for the first time. It won't boot, opens to a screen w/6 options one of them is continue.
I know how fix it if any still need help. You will need usb with windows 8 install on it, keyboard and micro usb hub, which take other devices get things from it, like gettin gwindows 8 start on tablet digiland. You need start device, press winodws key and alt, then it should start over bios mode, then go to first slot start windows 8 usb, then restart, wait it fully go usb then should be windows 8 install done right after waiting say 5-8 minutes see it, then should be able take it from there. I did it but having problems with updates it needs, which working on. Hey least get winodws 8 right.
Its running windows tablet so in short if you're running Windows 8 or above you should be able to easily refresh or reset your pc depending on your needs. Refresh will keep all your files except apps while reset removes everything. Reset is helpful if your system is infected or extreme measure to speed up. Refresh is great if you're experiencing some trouble but need to keep your files. Also you can use a Windows install disk and choose the new install option to have a clean operating system. Alternatively if you're experiencing technical trouble if you have system restore enabled you could use this feature.
To create a windows install disk use the Windows Media Creation Tool to make a bootable environment on a flash drive or disk, and boot from it. Delete your Windows installation and recovery partition, and install Windows from the environment. It may sound complicated, but I assure you, it's very simple.
Dec 6, 2015 - Take the Digiland DL718M, for example. ... I also found that the screenon the Fire has a yellow tint when viewing an ebook in the ... fire tablet digiland dl718m... I am happy with it, and that says more than you might think.
Dec 21, 2014 - With a 7" 5-point capacitive touch screen, this DigiLand DL701Q tablet makes .... Hi, my daughter was playing on her tablet and then the screen .... let me donothing just more error messages, when it says to report the error ...
? 1:55
https://www.youtube.com/watch?v=Yr7PTiaShQk
Oct 4, 2015 - Uploaded by Android Pro
Digiland DL700D Hard Reset .... I get the Digiland logo, then the green android, then nothing but black screen. ... DIGILAND 7" (DL718M) NEW ANDROID 5.1 LOLLIPOP TABLET HD DISPLAY UNBOXING - Duration: 4:12. by
You have got to hold down the power, volume up and down at same time, when its obvious it turns on the release the buttons and then ur boot menu should appear
www.askmefast.com > Consumer Electronics > Other - Electronics > Reset
source: How do i reset my digiland dl701q tablet when forgot pattern? ... up button but it doesn`t take me to a menu to do a · Hard reset tablet digiland dl801w.
? 2:02
https://www.youtube.com/watch?v=bfzSp3rxb18
May 14, 2015 - Uploaded by JrTech
How To Factory Reset Windows Computer Tablet ' Windows 8 Tutorial Wipe Data & Memory Hey techies ...
Just make a factory data reset.
To reset you tablet manually. you have to
1)switch of your tablet
2)hold volume down button and power button at the same time.
3)wait for 10 sec and you will enter into boot menu.
4)there in the boot menu you will find option named Reset factory default settings/reset user data. select that option
5) wait for resetting......
6)cheers your done.
