A
Azad Posted on Sep 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i clear error F2-70 on sharp AR-5623N copier machine?
Terry
Level 3:
  • Sharp Master 11,377 Answers
  • Posted on Aug 03, 2018
Terry
Sharp Master
Level 3:
Answers
11377
Questions
Helped
4623120
Points
152765
Http://printcopy.info/?l=en&mod=erc&brand=Sharp&model=AR5623N&code=F2%2070
Sharp AR5623N Error Codes
Sharp AR5623N Error Codes Code: All codes CH Blink CH ON E7 01 E7 02 E7 06 E7 10 E7 11 E7 16 F2 40 F2 64 F2 70 F2 74 H3 00 H3 01 H4 00 H5 01 L1 00 L3 00 L4 01 L4 31 L4 32 L6 10 U2 04 U2 11 U2 12
Code
F2 70
Description
•Improper cartridge (Destination error, life cycle error) •Identific t ion error •Model error •Type error •Destination error •Data abnormality •Misc error Detail •The destination of the machine differs from that of the CRUM. •The trade mark code of the CRUM differs. •The company code of the CRUM differs. •The boot program model code does not coincide with the CRUM model code. •When the CRUM type is other than genuine/ conversion/production rotation. •The machine destination differs from the CRUM destination.
Causes
CRUM chip defect Improper toner cartridge.
Remedy
Replace the toner cartridge.
5 Related Answers
Anonymous
  • 2072 Answers
  • Posted on Mar 17, 2008
SOURCE: Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
san3409jl
  • 190 Answers
  • Posted on Jan 27, 2009
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Warrick Lee
  • 32 Answers
  • Posted on Mar 25, 2009
SOURCE: Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Anonymous
  • 95 Answers
  • Posted on Apr 23, 2009
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
M2Tech1
Andy Bell
  • 313 Answers
  • Posted on Jun 12, 2009
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
1helpful
3answers
How to reset sharp AR -5618
how to reset the toner chip as it is costaly
Error h4 sharp ar-5316 can you help me ?
H4 indicates "low temperature", possibly caused by a failure of the heater lamp or fuser. Sometimes this error is shown without an actual damage when the power cord is pulled without shutting down the copier first.
To cancel the error code, press [CLEAR], [AUTO], [CLEAR], [AUTO] in rapid succession. The display should go blank. Next, select 14 (clear low temperature code), press [START]. Finally, switch off and on the machine.
If there was no actual damage (i.e. power cord pulled), the machine should be OK again. If the error persists, immediately or after short time of operation, you will need to contact Sharp technical service for repair.
11helpful
2answers
Sharp AR-163 Copier, How to Reset/Solve the error Code U2-40
how to clear red sing on tonal problem for sharp ar 163
9helpful
Sharp AR-M236 Fault U2-40
Hello sir; This error code require reset the procedure as follow;
press "#/p" " . " "clear" " . " then enter 16 press start enter 0 press start again, press "clear all" machine will back to normal.
1helpful
2answers
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
3helpful
Sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
10helpful
2answers
5helpful
3answers
try to cancel it by pressing: #-interrupt-C-interrupt simultaneously, then when the panel goes off input 16 then press the COPY KEY <> The machine will restart automatically. if U2 still remains.. try to replace the mainboard.
67helpful
13answers
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
