Hdmi port is not working - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 12,962 Answers
Use another one that works - repair of one is not cost effective. You can also get y adapters for the good HDMI port.
Posted on Sep 19, 2017
6ya staff
SOURCE:
Viera TH-L39E5K. Why isn't HDMI connection working?
Try a different HDMI cable first into all ports. Try every HDMI cable you have. Then try a different component into TV HDMI ports. If you are using the receiver to switch inputs, try running HDMI cable straight into TV. HDMI is very finicky. Some cables won't work or stop working for no apparent reason.
Nov 02, 2015 | Panasonic Televison & Video
Phillips hdmi ports not working
Yes,
When 1 HDMI port is broken most of the time all the ports are defect. This is because all the 3 HDMI ports are connected to 1 multiplexer IC. Only when the connector or the copper connection on the board is damaged the other two ports still be functional.
You still can use the other connections ( not HDMI) the should be working.
Regards GJ
Jun 14, 2014 | Philips 42PFL5332D 42 in. LCD Television
Just set up RX-A700 two things seem wrong. 1. HDMI 1 won't show video if HDMI is plugged in, once plug on HDMI is removed from receiver HDMI 1 works perfectly. 2. HDMI output needs to be held tight or else...
sounds to me like a bad HDMI cable. Just replace it.
If HDMI still wont show, move to another HDMI port. But based on having to hold HDMI cable with hand to steady the connection, it is either a bad HDMI cable, or a bad HDMI port on the receiver. Good luck
Jan 23, 2011 | Yamaha RXA700 Receiver
The hdmi port on my Panasonic CT-30WC14 only works when I push the cable into the port and hold it. It has a bad connection. I was going to take the back panel off and see if I could connect to the port...
Not the HDMI port,it the HDMI cable is dead.If u have dead HDMI port holding the HDMI cable wouldn't work,make no difference.Change the HDMI cable will solved ur problems.
Sep 06, 2010 | Televison & Video
I continue to have to switch my HDMI cable between 2 ports on my TV because initally there is "no signal". But when I switch ports I get a signal. So is this a HDMI cable issue, port issue or my Insignia...
My best bet would be a port issue - see if another device will work plugged into that port. (Some HDTVs have a HDMI port strictly for Service and nothing else but a Technicians specified cable will work in this port, look at the Manual) Check to see if your TV is set to the same port as your connecting to. One will be HDMI 1, next HDMI 2 and so on, the input button on remote should switch from port to port, make sure port setting on TV is same as #port your connected to.
Jun 17, 2010 | Insignia NS-BRDVD Blu-Ray Player
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
No sound on DVR HDMI port, but does work on other HDMI port
Not all HDMI ports support Audio or they do but only one way Audio out or Audio In. If you have an optical connection you can try that.
Apr 04, 2010 | Yamaha HTR-6130 Receiver
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
I have a 37" Insignia L37Q tv with 4 HDMI inputs. Only HDMI 1 works properly. If I hook up an HDMI device to any of the other HDMI ports I get one of the following: 1. No signal 2. Not supported 3....
Try plugging hdmi cable into hdmi 1 on your TV, then open the menu on TV and find the place it lets you to make selections on this, such as Satellite or hdmi 1. One of these selections have to work.
does the hdmi port gets detected when you try in other hdmi ports.if not getting detected then it can also be fault in the hdmi ports.because as you said that hdmi port number 1 works.that means wires are proper.but other hdmi ports not working that means the ports are faulty if all the setting are proper in setup.
as the ports are soldered to the unit internally.if the soldering gets loose the connection will not get complete.so re-soldering is required to the loose ports.
if you are not familiar with doing this you can get it done by local repair technician familiar with this model .
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 16, 2009 | Insignia NS-LCD47HD-09 47 in. LCD TV
No sound through HDMI port on rear of tv
You could replace the HDMI port on the TV, it's no different than changing a USB port card in your computer. But, finding the replacement HDMI port card for your TV can be tough. Try shopjimmy.com for parts.
Jan 27, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
