You need to Flash ROM
Visit to download by your mobile model number:-
Download Vodafone Stock Rom for all models
SOURCE: PHONE IS LOCKED
you need to factory reset your phone. this website shows you what to do without having to access anything on your phone - the first step is shutting it off. follow these steps and your phone will turn on, the only drawback is it will be like its new, and you'll have to re-download all the apps and stuff. it also has you sign up for gmail, and i suggest that you create a gmail address and write it down so it doesnt happen again :)
http://androidcentral.com/factory-reset-tmobile-g1/
SOURCE: ive locked my g1, too many wrong attempts on
1. Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
Now to wipe the device clean:
3. Press Alt+L.
4. Press Alt+W for a factory reset.
5. Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
SOURCE: i attempted my unlock pattern to many time now my phone is locked
you will have to do a master reset....you will loose everything on the phone....it is important that you create a google profile, which will back up all your contacts....
if this doesnt work is because your phone doesnt have the harware keys firmware update... need to take it to a repair center and have do a software reflash
SOURCE: samsung galaxy s6102 swipe lock so many patern attampts and my email not open in login phone
volume up and power button until you see the android guy, erase data/factory reset, if this is too plain let me know i will break it down, also let me know if it does not work good luck questions just ask
