Samsung Electronics'Washing machine not spinning' is one of the major problems faced by people nowadays with ... If so, the washing machine can't spin and may not function at all.
May 13, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...
Your program controller unit is working but it must be ensured that there is output on every cycle to the desired output controls. So the inlet valve must work and the motor must run when the water level is triggered by the level controller. So use a meter to check before we can suspect the controller.
I've just had the same problem with my Samsung SW50USP and had a technician out to have a look at it. Apparently the electronics are fried and it would cost much more than it's worth to fix.
Time for a new machine unfortunately.
Ec indicates a problem with the thermistor or temperature sensor.
Repair and service your own washing machine.
kindly check them out....
thank you
have a nice day
