SOURCE: Flashing with error code '0xc090003'
This is memory overflow problem. Lookup for the Reset button at the front panel and press it once. Switch it off and leave for about 10 minutes before powering. Good luck.
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
SOURCE: my affinity frigidaire dryer keeps flashing an E9E error code
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
