How do you change out the battery in a BFit watch? I took it to a jewelry shop and they could not figure out how to remove the battery. It is by American Exchange.
SOURCE: Can't figure out how to change watch strap
Hi, try this - it worked for me. Use a needle to poke the ends of the watch strap axel (at the end and running across the strap). This should then allow you to lit the silver panels at the top and bottom of the watch face off. The axel should then slide out. I did this by pushing one end of it through with a needle so that the other end poked out enough to pull it out with a paid of pliers.
SOURCE: i had the battery changed
Take it back to the jewelry store and explain what happened. Be nice but firm.
SOURCE: Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
SOURCE: Battery change Citizen Promaster Watch Model# C112.
mcdevito75 here, You should be able to get some help online at citizenwatchserv.com in the meantime you can try to press and hold in the MODE button, press and hold it in for a couple of seconds. Also< IO wouldn"t be surprised if the battery has to come out and installed again, same new battery just simply have it taken out and put back in, maybe some sort of re-set. Check out the website, don"t do anything till then.
SOURCE: We bought the Fossil Brown rectangle watch model
