SOURCE: Color of people's faces in movies played via DVD is now blue since connected to LCD TV
The reason the picture is blue on the DVD is because you have poor video cables running the feed, probably RCA yellow cable im guessing. Get some nice component cables for the DVD feed and it will fix you right up.
SOURCE: Cant connect LG Renoir via USB, connection problem
I get this all the time and it is really annoying.
What I do to solve it for me is to is to tern all my mobile application off and then reconnect the USB cable.
To close all open applications: press the white hard key (in the middle of the red and green), and you customisable menu appears. At the top of the screen is a grey tab with a dark grey triangle (like a play button), press this and you see all (if any phone application are open), press the end all button on the screen. Then to confirm action pres yes to stop all tasks.
Hope it solves you problem.
SS
SOURCE: LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
SOURCE: Cannot connect my LG Viewty to the computer via the LG PC suite
hey.. if u connect ur phone via usb, be sure that ur phone is in home screen, because if not, for example if you connect your phone and you're in your message menu then you will open some apps in your pc suite the message will appear saying 'Fail to connect to the mobile handset, Please check the COM port and connect in idle screen. Due to the multifunction, despite idle screen, it can be failed to connect' now try it by connecting the phone but in home screen mode.. gotcha buddy?? hope soo..
SOURCE: My kenmore series 80 electric dryer does not heat.
Yes, hook it up, but before you do that Vacuumn every piece of lint out of the cabinet. Also check TCO and check the thermostats for continuity. They should all read zero ohms.If one of them is open, replace it.
Also use your ohmmeter to check the heating element, It should not show an open condition.
