SOURCE: TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
SOURCE: setting up wifi on my LG Viewty
Unfortunately the LG Viewty does not have wifi.
I also have a viewty, and I find that with a cheap data plan and the 3g internet speeds, lack of wifi isn't really a downside.
SOURCE: Same problem - Wifi is greyed out, says No WiFi
Are you sure this is the original iPhone. I've noticed this same problem with the nokia N95.
SOURCE: When using WiFi, in Settings WiFi, the tick
If you don't see the WiFi signal on the status bar, that means you're not connected.
Visit my blog for more iPhone / iPod touch tips.
SOURCE: Can't use WiFi on Aino
Guys i foun a solution for the problem.
Just enable content sharing and in the connection setting window in the browser set allow local connection, and then it will use the wi-fi . cheers
Take the LG Optimus 3D, put it on AT&T's network, and what do you have? The LG Thrill 4G. Inside the Thrill 4G is identical to the Optimus 3D... and that's a great thing. With both 3D recording of pictures and videos and the ability to view 3D pictures and videos wihtout the need for special glasses, the LG Thrill 4G will certainly be a thrill for its owners.
Beyond the exciting 3D integration the Thrill has other awesome features as well including a 5MP camera, 4.3-inch screen and rocking Android 2.2 on a dual core porcessor, the LG Thrill 4G for AT&T is destined to please the masses.
