Question about Panasonic Televison & Video
I have a Panasonic TH-42PWD7 plasma, when turned on I get sound but no picture. The screen is flashing colors(blue, green, white, red). I'm able to switch to DVD which plays/ displays properly.
TV mode only sees flashing colors & sound. I unplugged tv, tried the up & down arrow to reset it but nothing works
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
TAKE TV OUT OF TEST MODE LOOK YOUTUBE HOW 2
Posted on Sep 28, 2017
6ya staff
SOURCE:
Vista Electronics
  • 1694 Answers
SOURCE: Convergence
Loss of power supply voltage to run convergence circuit.verify w/service literature.Hands-on technical help needed.
Posted on Oct 09, 2007
dewan nafees ahmed
  • 1894 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
was that capacitor damaged?
Posted on Jan 11, 2008
Anonymous
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
lee51674
SOURCE: plasma TV with vertical lines
Curious why is the kdl55xbr8 way more expensive than the kdl46xbr8 and this is the only tv in the market that holds its value..true?
Posted on Mar 19, 2012
nemesis10
Roberto Lecaro
  • 4 Answers
SOURCE: funai 32 inch plasma tv
http://www.tvrepairdoctor.com
Posted on Nov 24, 2012
I can't get a signal because this tv don't have cable antenna terminal the tv has rgb terminal. I don't know what to do?
RGB is for a computer screen display signal and has nothing to do with TV display of channels. You must have a Component hook up, it is a yellow cable, a red and a white one. Yellow is video signal, the red and white are sound.
Sep 12, 2016 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
How to set up the colour on my Panasonic Viera TV
http://service.us.panasonic.com/OPERMANPDF/TH42PZ80U.PDF
Here is a copy of your users manual, it tells you how to adjust the color on the TV, Magnets do not affect Plasma TV's. If your picture looks bad you might have a defective or failing part if you just need to turn the red up or down or make the picture more blue or green the users manual tells you how to adjust it.
Sep 10, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic plasma TV TH-42PWD7 blacks out..
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 20, 2014 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
How do I connect the DVD player to a Panasonic High Def Plasma TV?
Choose connections on the Panasonic that match those on the player--
Do you have on the player Component outs(blue,green,red and 2 audio which are red and white? This ought to give you the best picture and sound.
Other inputs to the set must match the ones coming from the player--Most owner manuals have a lot of details here.
If the player has 1080 output hook to a similar input on the set.
Some advice here: make the connections between units with both turned off.
Apr 03, 2012 | Durabrand DVD-1002 DVD Player
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
Jul 25, 2011 | Panasonic Viera TH-50PX80U Plasma TV
How i do tv chanel tunig
Hello Ansarielectr, The Panasonic TH-42PWD7 is a professional grade progressive wide screen plasma display. It's not your normal HDTV. You probably already know this. This display requires a component /composite video terminal Board that mounts to slots 1 & 2, or slots 2 & 3. The item number for this component is TY-42TM6Y and can be purchased through the Panasonic support website here for about $270. Once you have this component, you can connect the TH-42PWD7 to a digital HDTV cable box to receive signals. Just make sure you're on the right input signal. Hope this helps.
Dec 28, 2010 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
Dvd player connected to panasonic viera. picture has blue skin tones and picture isn't centered
I always try the simple things first. check the connection. if hdmi .. then try a differnt cable.
It almost sounds as if one of your connections is plugged in the wrong place.
On component.. red to red, green to green and blue to blue .. then the extra red and white go to the video part .. also may want to check the tv manual - sometimes they share those connections with regular rca connection and easy to plug in wrong place.
Rca connetions - Yellow is video - red and white audio.
S video - one big plug and then red and white audio - make sure the big plug is fully in on both devices - I've seen similar things with s-video plug not fully connected on one end or the other.
Good Luck,
Bill.
Nov 29, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic TH-42PD25 The picture is black with
Make sure if your using the video input jacks, that the yellow is plugged into Video 1 and the same with the audio.Red & White. If your using Component, they are color coded- Red Blue & Green along with the Audio In -Red & White. It sounds like you have the video in the wrong jack.
Oct 28, 2009 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Panasonic VIERA TH-50PX25 DVD offset and blue color My DVD or VCR is offset on the screen ... ...
this Plasma TV working normally for 2 hrs & just stop &showing blackscreen display"chanel not available" I turn TV off & turn it back on again ,. now it have picture with no sound ...please help if any one know what is the problem is ...Thanks
Oct 08, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Televison & Video Logo
147 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
